Strange stuff happening after 14b install.
boosted99_420
307
Apr 26, 2010
Fort Carson, Colorado
Ok so i started out doing everything by the book. I installed a 14b and a Mishimoto FMIC. After i finished i did the procedures and got car started and started to hear a poping sound coming from what i can tell is manifold area (Not turbo). I have a boost leak i have to fix but turbo is still sending boost to engine. My stock Boost guage no longer works because i have no way of hooking up a vacuume line from the Compressor houseing to the sensor. Is there a way to by-pass this and also what is this poping sound, im tightning up any loose bolts tomorrow. New J-pipe tomorrow also.
Ok fixed the waterleak, boost leak, and boost guage problem. Now i have an oil feed leak (which is my stupidity for thinking the stock t25 oil feed would work). and the popin from what i can tell is an exhaust leak on turbo/manifold gasket 2 bolts dont fit in turbo correctly. BTW does my manifold need to be ported since i am using a ported 14b, or is it fine like it is in stock form?
What did you hook the wastegate up to?
its hooked back up like i took it off from the t-25, im thinking of running a manual boost controller do you know a link that has how to hook it up right?
