Strange noise when spooling up?
98gst14b
453
Jan 24, 2006
Keys, Florida
I have a gst with a e3gt. Recently I have been hearing a strange whistling, whining noise whenever I spool up very similar to an alternator interference with a stereo. I checked the turbo and its perfect no play at all. Could it be a boost leak and air is whistling out? Thanks for your help.
i would say looking at your profile since you have a fmic look at all the piping, check the tb elbow to tb. Check by the injectors since those are upgraded...look around anything that has been upgraded.
Compressor or pump ? What pressure and how long did it hold ? Engine hot or cold for test ? Was the engine at 30* past TDC ? Did you listen or did you use spray bottle with soapy water ? Listening does'nt count .
Used a plumbers cap with a tire valve, pumped to 20 psi with bike pump. Engine was hot, air was leaking out mbc weep hole, held over that and watched pressure, dropped extremely slow if at all. Tried tightening the bov a little and sound still persists. It honestly sounds like death whine from a shot turbo but I checked play again and perfect. I might add recently it has been kinda cold (about 50-60 deg) could the air density make this sound?
Man mine has starter the same thing now that it has got cool out. No leak either, I need to see what folks say also.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
