Strange Idle problem
DSMNewbie09
Jun 1, 2009
brooklyn, New York
I have done alot of research on this site and it seems like no one has a simular problem.
When i start my car the idle is perfect for about the first half minute then the idle starts to drop and act like it is going to stall then after 2 and half minutes of the car being in idle the Rpms go back to normal and the car drives perfectly like nothing is wrong. if i turn the car of and then back on right away it starts all over again so it has nothing to do with the car being warm or not.
the TB has been cleaned.
I tryed ajusting the BISS which fixes the problem for the first 2 and a half minutes then it jumps up to 2 RPMS.
the TPS looks like it has no problem at all.
i have also tryed reseting the ECU but that didnt help either.
any sugestions will be helpful
Maybe you have something pulling voltage. that would make the rpms drop. Put a volt meter on it, and watch to see if somethings turning on to put strain on the system. Mine idles low when the fans come on until they kick off.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
