strange idle issues
Thomas91169
4,490
28
Jan 18, 2004
modesto, California
so today i go driving to the local Target to pick up some of those tote thingies.
when i get back on the road again, the first stop i came to, i put the clutch in and the revs never dropped to normal, they hung around 1200. so i think nothing of it. i go down the road some more, and stop and the rpm's hang around 1500 now. so now im like "wtf is going on baby". i keep driving home, fiddling with the gas to see if its maybe hanging up on something, but no avail.
by the time i got home, it would hang around 2000 rpm's. when i pulled into the garage, i just let it sit there at 2k to see if it would come down, but it didnt. so i fiddled with the throttle and gave it some revs, but it still hung at 2k. so i shut it off and stuck a fan on it(so i could cool it off and work on it later) and went inside and did what i planned to do(clean out my room)
so later in the night, after the engine was cool to the touch, i started it up and took off around the country. the idle was fine, when i put the clutch in it came down to 600ish like it usually does.
could it be heat related? my temp gauge never went above the middle. it was around 100ish when i went to target today, but i went top down and never touched the a/c. oh and speaking of which, when it was idling high, i tried running the a/c, and when i came to stops it went down to 1000 rpm's, but with the a/c off it hung at 2k.
im thinking about a full radiator flush and adding some water wetter(i hear it helps).
any input?
Well, my talon when i first turn it on it goes up to 2k and stays there until i put it into gear and drive it. Im thinking i could be the Arizona sun, its just not cool down here :cry:
