Strange Fuel pump relay clicking after it's running.
1gcrazy
1,552
9
Apr 6, 2005
Fountain, Colorado
So I bought a car with a shit motor(an entirely different story). Bring it home and rebuild it. Install the motor and start it up. Little did I know I was getting 3 CEL's 13, 31, 21. Maf, knock sensor and Coolant temp wires(I think). All fixable. BUT, when I started it and as it ran for a few seconds I'm getting multiple clicks from the Fuel pump relay under the radio. The fuel pump is wired with a switch due to the dipshit PO.
Not sure if it's what's making it cut out, guessing it's mainly due to the maf since the throttle basically doesn't work. I swapped out the relay with another one and it's still doing it.... I'd like to figure out what's doing it so I can kick the fuel pump switch and make it factory again....
Here's what i'm talking about...
View My Video
The connector on my MPI was melted causing intermittent connection to the relay. I cleaned it up and repositioned the pins in the plastic. It has not dropped out in a while. I have an emergency toggle switch wired up just in case however.
Huh?
My MPI relay was changed out with another one. No less tension than normal. Looked in good shape.
I never figured it out but the blinkers were also on the fritz. I decided to wire a relay into the ignition which didn't exactly work correctly because of what I've come to determine was a wrong dash wiring harness installed into the car previously. It was a nightmare and I sat on the car for MONTHS trying to flip it. I barely got out alive. The GI who bought it knew about all the problems and was particularly cocky. He decided he could fix it and I never heard back. I found the car on Craig's 6 months later... Said he was getting deployed. Doubt it was fixed.
