AWDPetmitsu
- 1,054
- 15
- Jan 26, 2003
Pennsylvania
Lately the stock oil pressure gauge has been acting up on my 1G GSX. It reads ok but intermittently it will drop to zero and stay there for several minutes and then it'll go back up again to normal as I keep driving. Sometimes it doesn't move at all when I first start it up but then it'll start working and then drop to zero and stay there until it decides to work again as I keep driving. I've replaced the oil pressure gauge sender and the oil pressure gauge itself too and checked the wiring and connectors. When I ground the circuit, the gauge reads maximum so the wiring should be ok. Also, the low oil pressure warning light doesn't come on when the gauge drops to zero so I think I should still have good oil pressure when it happens. I'm totally stumped at this point and wondering if anyone has ran into this issue and have a solution? I don't want to run an aftermarket gauge. I just want to get the stock one working properly again.
. It's also very annoying to me.
