1G stock oil feed line turbo
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
hello i take off my turbo and now I put them back and Im not sure if hole in the screw must be equal to the hole in oil line fitting ? or can I just screw in and the oil will go to turbo anyway ? trubo oil feed line and fittings are stock
The holes do not need to line up. If you look at the banjo bolt, there is a depression all the way around that area for oil to flow. Ensure that you use two crush washers (one on each side) and torque to spec.
does anyone know torque spec for water line screw to turbo and oil feed line screw to turbo?
32 is the water line that screws into the water pipe coming off the water pump
does anyone know the correct size of copper crush washers for oil feed to head, oil feed to turbo, coolant water to turbo.
here is the list of sizes
1-Inside mm 2- outside mm 3- thickness mm
i know that i need to buy 10mm 12mm and 14mm inside but which outside and thickness ?
easiest thing to do is google the part number
-- (quantity) part number
13g
oil feed line -- (4) MF660063
water lines -- (4) MF660064
14b
oil feed at head (2) MF660063
oil feed at turbo (2) MF660064
water lines (4) MF660065
