stock injectors?
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
when i typed my topic in the search box did not open up. i was wondering, i have a 1993 eagle talon turbo FWD and was wondering what the stock injector size was that the car came with? i bought mine with 550cc injectors.
Fuel cut will also depend on the elevation where you live, when i first bought my car i was hitting fuel cut at 25psi (po installed boost controller incorrectly) But i could hold 20 psi all day long. This is with stock injectors as well! I live a few hours from denver colorado though so up here in elevation our cars turbos have to work harder to acheive the same flow which = a greater overall psi to obtain such flow. So technically there is no magic number because as stated above there are a dozen different variables to take into consideration. Also if you have 550's i highly doubt there is no tuning device in the car otherwise it would most likely not idle at all and run horribly.
I ran 17psi at 7200 feet.... Came back home and took a drive..Fuel cut, had to back it down to under 14...
But the strange thing..When with my currently broken turbo It could creep up to 20 psi and not hit fuel cut...
thanks for the sites numbers helped
found out i got to 1G DSM Turbo AWD 3/89-6/90
so will it work in my fwd 93 eclipse?
If it's in good condition and you swap pins 6 and 14. They changed locations between the 90 model year and the 91 model year on the ECU connector.
  • Wanted 6 bolt NT water pipe
    • chrisman287
