stock fuel pump flow rate?
bradselph
Supporting VIP
917
12
Jun 14, 2010
sebring, Florida
Please don't answer unless you know for a fact!
Does the fuel pump in a N/T Spyder have the same flow rate as other 2g turbo eclipses?
And yes i did search, i found only topics asking about aftermarket pumps.
So your factory 420a pump was larger then our turbo 4g63 pumps.. Interesting.
I'm not 100% sure, but my answer is better than the prior. I'm 90% sure it's like a 140lph. Maybe someone can tell you what a 420a flows.
My 420a stock pump was 190lph. Maybe this will help.
this doesn't sound right... it seems like the turbo pumps would flow more than the non-turbo pumps, or that people would recommend the 420a pump as an upgrade instead of a walbro/evo/3000gt...
And sadly i don't believe your "Stock" pump flows that high.
When i do know a 1g turbo pump flows at only 108 LPH at 58.5 PSI.
So far i believe hubz at 140 LPH can anyone else confirm?
Well ima revive my old thread with some info
I upgraded my fuel pump to a evo 9 and while looking at the old pump i got these numbers.
"Denso 195130-2231"
So far google tells me its a 420a pump so what do they flow at?
