Stock Fuel Pressure, what it should be and how to test, help?
Trelisong
88
7
Sep 6, 2006
Denver, Colorado
I just got my fuel pressure banjo adapter bolt and hooked up a pressure gauge.
At idle my fuel pressure is showing 36-37 with the vacuum source attached to the regulator.
If I remove the vacuum line from the regulator then my fuel pressure goes up to 44.
I am under the assumption that a 2g is supposed to be at 43.5 PSI, however I am unsure if you are supposed to see this amount with or without the vacuum line attached.
First, Thank you for the response! exactly the information I was looking for.
Actually I did search for : fuel pressure
it returned 20 pages.... I started to scratch my head after reading through a couple pages and not finding my simple answer.
When vacuum line is connected, it should drop 1:1 with the manifold pressure, 1psi = 2inHG.
    • george bromwell
    • pma1123
    • Sdcryan1
