Stock boost gauge broken
killerwhale
128
Aug 10, 2007
Victoria, BC, Canada
Anyone know what the problem could be? I have an aftermarket one but I miss the stock. Plus, if I remember right the stock measures vacuum too doesn't it?
I figured I would post before taking my dash apart.
Thanks
Thanks
LmaooooROFL
The stock boost gauge is crap and even if it was working you still shouldn't go by what it reads.
Take our advice
Now it's established that the stock boost gauge is useless, someone chime in with where it gets its information so he doesn't have a dead gauge in his cluster if he doesn't want it. Can't recall at the moment. All I know is that it's not from the boost control solenoid or vacuum nipples on the throttle body.
It gets it's information from the ECU. The ECU extrapolates a speculated boost reading based on RPM, throttle angle, and airflow. Make a huge boost leak, and the boost will read infinite pressure. Disconnect your MAF, and it should read zero.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
