Boost Gauge Broken
gstrb91
Aug 1, 2004
San Antonio, Texas
I have a 91 Gst and the stock boost gauge doesnt work, i bought the car with it not working then i got a new turbo and it still doesnt work what do u think could be the problem. the needle sit all the way down doesnt even go up to 0. any help would help
ddavisaf said:
Get a aftermarket gauge...
Yes, boost gauge should always be the first mod especially before a turbo upgrade. Even if the stock gauge is working, it still doesn't work because it doesn't measure the real pressure, instead it guesstimate according to sensor inputs to the ecu.
i have a aftermarket gauge just wanted 2 fix the stock one, removed the cluster and put it back made no difference, not sure about the ecu, how can i check
Take it out of the center console. Check the number on the case against my ECU list and even if it shows as a turbo ECU open the case and look for the knock board in the upper right corner to make sure nobody changed the board. The 4 digit number on the white connector should match the last 4 digits of the E2T number on the case if that board came in that case.
Steve
:nono: ROFL, you guys crack me up, your mas air, is not plugged in, or is not working, so plug it in, or get a new 1, thats your problem, ROFL, a NT ecu, cmon now :tease:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
