Stock & ARP Head Fastener Sizes?
daren_p
DSM Wiseman
4,605
98
Nov 22, 2004
Newmarket, ON, Canada
Was wondering if anyone could verify the stock head bolt size and the size of the ARP head studs? I don't have metric 12 point sockets for the stock bolts but it looks like they are 12mm? Unless the ARP nuts are Metric, they appear to be 1/2"?
Your stock 7 bolt head bolts are 12mm 12pt heads, 11mm diamater.
6 bolt head bolts are removed with a 10mm Allen head driver.
7 bolt ARP head studs are 13mm 12 pt. nuts, 11mm diamater studs.
6 Bolt ARP head studs are 14mm 12 pt nuts, 12mm diameter stud.
You need a 12pt, 12mm socket to remove your OEM head bolts.
95blackGsTurbo said:
ARP are metric 14mm 12 point.
That isn't correct for the 7 bolt studs, atleast not mine. Are you sure about ARP being metric? While 13mm will work, 1/2" is slightly smaller and fits the ARP nuts perfect. Yes the stock 2g's are 12 mm.
in my experience with the ARP's in my 7 bolt the nuts are a 12 point 13 mm..fit perfect for me and fastened fine..
Chris:dsm: :talon:
I forgot to mention I was talking about 6 bolt studs. I thought you had a swap because in the last post I helped the guy did a swap. Simple mistake. And how is that wrong. The wiseman under me said the EXACT same thing.
It wouldn't be wrong if we were talking about 6 bolt studs because they are apparently 14 mm, but we were talking about 7 bolt, so that isn't correct info . The wiseman didn't say the EXACT same thing as you, he stated both the 7 bolt size which pertains to this post and also the 6 bolt size for reference, but had each one labeled.
The correct sizes are not metric. On my old regular arp for a 7 bolt, the nuts do not have any marks on them. A 13mm 12pt will strip if you dont hold it perfectly steady. The correct size that fits the best is 1/2 12pt.
My L19s newer nuts have 7/16th (stud diameter I think) written on the side but a 1/2 12pt is needed. Using this size I was even able to remove badly stripped nuts.
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
