george5366
- 126
- 1
- Dec 29, 2004
Stockton,
California
Ok i replaced my clutch with an act2100. after that the disengage point was to the floor. about 2 inches up. so i:
replaced: master, slave, and an extension rod for the slave(which helped). i will bleed it and runs perfect, but after a while it will start filling mushy, and go back to the floor disengagement. it doesnt run out of fluid or nothing, the resovoir is still full. so i dont think theres a leak. what else can it be? i searched and found all the ways you can bleed it, and did them all. it works but then it goes back to being a mush clutch. should i replace all my clutch lines? is that the last thing it can be externally?
i dont think its the clutch fork because it does work good, but it just goes back to being bad
