starting problem
hawkman gsx
87
Aug 6, 2011
bedford, Kentucky
My car wouldn't start yesterday it a good while for it to start it done this two times I checked the spark plugs and they were good it hasn't done it today if anyone has had this problem and can give me any hints of what could be makeing this happen thanks guy
I feel ya. I had the same problem. I checked everything. I looked at the schematics to check everything in the fuel/spark areas.
Check the cps and the cas carefully. When they were plugged in, the car seemed to crank unevenly... when i unplugged either one, the car cranked smoothly but still no start. Turned out it was the cps having a connection issue. Also check the fuel pump relay.
Does it not start mainly after setting for a couple hours, but start right up after a couple of minutes of setting if so pull you vacuum line on you fpr and see if there's fuel in it. Could be loosing fuel pressure in system due to faulty fpr, and its just priming the system when your cranking it.
