Starting out could use some advice
Starpower1987
Feb 18, 2019
Brook, Indiana
so like the title says im starting out for first time ever...i have a 95 gst i plan on converting to awd with help LOL. i want to get close to if not 500hp. i would like to kinda do it one go instead of putting this car together just to have to take it apart again...any suggestions on parts and what i need to get there would be greatly appreciated...budget isn't too much of an issue as this will be a project car and can get it piece by piece...ty you again
Take a look here to get started.
https://www.dsmtuners.com/threads/basic-horsepower-ugrades-2g-4g63t.480196/
I also suggest filling out a profile for your car so everyone can see where you are at currently and what you need to get where you want.
I will add some things. Repair the vehicle and make sure it is safe to be driven and fully functioning. Things I am talking about are tire, brakes, suspension and general maintenance, such as timing belt and leaks. Think twice about your goals as 500hp is a lot so with that in mind buy parts that you won't have to replace down the road, common sense. If you wish to do awd swap then maybe that should be your first mod.
My advice is if you plan on 500hp then build it for 700hp. Give yourself room to grow. I originally only wanted 400hp and now I'm close to 700. But I over built it so I didn't have to do it twice.
