starting issue
gnen1st
96
Sep 26, 2008
tampa, Florida
Sat i was driving the car like normal and it was running great all day. I decided to see a movie and when i came out the car started fine no issue. Then when im going down the garage ramp the car dies out . It wouldnt crank over or anything. I pop the hood and see the fuse for the ignition sw blew out. Since it was too late to get a fuse i had it towed home. When i got home and changed the fuse it blew out again when i try turning it over. The starter is coming on the battery is new and that alternator is good too. I check all the connections and grounds and the lines are fine. Any suggestions on what i may be? Thanks in advance.
Sounds like you have a hot wire thats bare and laying on ground under the hood somewhere . you'll have to look for the signs . check the alt wires near the o2 dump first.
How do you know the battery and alternator is good? Have you gotten them tested? Even if the battery is new and may seem good,it's possible to have a bad cell and you wont know till you put a load test on it.
the battery starter and alternator have all been tested and are good. im thinking its a ground somewhere so im taking a look over all the lines to see if there is a loose ground somewhere ...wish me luck
It's not a ground, it's a short. Bad ground=no circuit. No circuit=no current. No current=no blown fuses. It's possible that a bad ground will cause current to find a ground through an alternate path, but your ignition circuit powers-up lots of things. there are lots of places to check for some bad insulation.
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
