Starter Grind, flywheel/starter marks
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
SO my starter has been doing this for a year now, i replaced it last summer and it never did it before..
4 years ago, we replaced clutch and all that jazz, and the starter didn't do this, i replaced starter last summer because it ended up stop working and the new one ended up grinding for some reason..
Well; i got lazy, i admit it, i messed up. Anyway; now that we are past that part..
I have read all the articles on this and i found a few useful posts but i wanna hear your opinions on my issue..
The starter grinds on startup, it sounds like metal to metal, and i know for a FACT that it is contacting starter to the flywheel..
WHAT could cause this, and WHY?? Also, i saw there are different starters i should watch out for.. what should i stay away from? what should i use?
The car is a 1997 Eclipse GST FWD.
Are you using the correct starter and starter plate for your tranny and year? Some people who do swaps and conversions (perhaps a previous owner even) forget this. Also remember AWD and FWD have different size and #teeth flywheels.
http://www.dsmtuners.com/forums/new...459007-bought-my-first-dsm.html#post153217957
For what i know, the starter is right.. i believe its still the stock tranny that came with the car when i bought it, i haven't swapped it out.. And i have a FWD flywheel.
Ended up being the starter was bad from the factory =)
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
