flywheel grinding into starter
monsterAWD
Dec 14, 2010
ironton, Ohio
:confused:ok guys im new to the dsm world ive owend one befour but i never got a chance to mess with it but anyway my problem is my flywheel is grinding into my starter at first i thought it was a spun rod baring because of the way it sounded until i pulled off the starter and saw the flywheel was grinding in to the face of the starter the car use to be an auto if that would make a diffrence any help would be grate cause ive had the car for three mounths and ive drove it twice LOL
I'm not sure if its there or not to tell you the truth LOL I was wondering. If it had an auto starter where it use to be an auto
definately check. The starter will engage and start car without the plate, but with out the spacer the flywheel may rub on the nose of the starter.
Ok well I got a starter an once the snow clears ill check for the plate and put the new starter. On and see what happens. What does the spacer plate look like thanks
