Starter doesnt engage flywheel
MollEclipse
52
Apr 20, 2006
Pittsburgh, Pennsylvania
I did a auto to 5 speep swap on my 93 eclipse i. when i went to start it the starter spun but didnt touch the flywheel. I went and bought a new starter but im starting to think i might have got the wrong flywheel. my clutch lined up fine. I dont know what it is.
Well you didn't post many details like FWD or AWD. I'm assuming you had an auto FWD and switched to a manual FWD. If so you probably got a hold of an AWD flywheel.
EDIT: Post more info. Is turbo or NA, is it FWD or AWD.
Was there a spacer/collar behind the flexplate?
It is not required with the manual transmission flywheel.
I'm having a similar problem with my 96 Eclipse. I just did an engine swap and have it all set to go except that the starter pops out and spins without engaging the flywheel. The flywheel that was on the car had the numbers 63NK on it and the flywheel on the replacement engine has the numbers 63TEK. Do these mean anything?
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
