96 GSX Starter Won't Engage Flywheel
Johnnyboy95
Jul 30, 2015
Fort Collins, Colorado
I have a 1996 GSX. I dropped the engine and tranny to do a rebuild. I've put everything back together and went to turn the car on. The starter wont engage the flywheel. It is the same stock awd flywheel and the same stock starter. You can hear the starter spinning and its getting power but wont engage.
Any threads or help will be very helpful and very appreciated.
Thanks
Sorry for the extremely late reply. Yes I have grounded the starter to one of the starter bolts also I have bench tested the starter after cleaning and reassembly and it tested fine. After the bench test and reinstalling the starter it still makes the same spinning noise and every now and again you can hear it trying to engage the flywheel but not plunging entirely. Could spacing/shimming be the issue? It was the original shim plate and is torqued down correctly to 22 lb/ft.
When you bench tested the starter, did the bendix fully extend?
Can you get to the solenoid to tap on it while the starter is spinning without engaging?
Update: Installed new OEM Napa starter. Car just sits there and goes chug chug chug. Bad sensors or compression should be the next step to check for right?
Special effects don't really help that much on describing an issue LOL. I am guessing it's turning over with apparent sound of compression but doesn't start. Check the following:
1. spark plugs and wires
2. fuel pump activating while turning
3. timing set in the correct position
4. compression (if it's low put a little oil through the spark plug holes and try again)
5. crank/cam sensor resistance.
Is it cranking at a quick speed? I used to have issues even with a new starter that it wasn't getting the amps needed to crank quickly.
