Started my install
tell you the truth man, I'd either leave the 7psi spring in there, or use a 5psi spring with a boost controller.
If it were me I'd just save my money on the boost controller until I'm ready to go higher than 8 or 9psi.
Remember 5th gear pulls, or uphill pulls will put more strain on the motor, and will also change how much boost is coming in.
But I must say, your Sh#t looks hella clean, I'm even surpised you got the stock front support back on there.
Hey thanks Rand yeah i got it back on i need to trim maybe 1/4" off so it doesnt rub the intercooler and so i can get the 4th bolt in it, but tommorrow i was planning on putting my tranny cooler in but tonight i noticed that have a headlight problem on the pass. side so i gotta figure that out, if it isnt one thing its another, maybe ill get it all back together.I know one thing though it drinks the gas under boost:(:talon:
Looks nice. Like Rand said props on getting you your front support back on. My IC is too big for me to put mine back on. Hope I don't have a front end collsion when I get my car running again (knock on wood).
Hey thanks i still need to cut maybe 1/4 inch away cause its rubbing the IC and fix my headlight problem,and my keyless entry stopped working AND i cant lock my doors via the switches inside i must have knocked a ground loose,unplugged a connector or my battery being unplugged for so long reset my alarm box :-\ and its raining so maybe ill get to it tommorrow.
yeah just charge up the battery, take off the door panel and make sure the windows are connected. I dunno what your headlight problem is but I bet it can be fixed by replacing the bulb housing connector thing. Just get a new one and splice some wires.
The door lock problem miraculously fixed itself i guess its a short or bad ground.But i got my bumper and tranny cooler on today, shes in need of a wash tommorrow and i need to replace a bulb,oh and the headlight problem was a corroded connector.things are looking up thought now i just need some what nots(bulbs,new air filter(ugh), wash her and fix my alarm :) ill post pics tommorrow when shes clean.
    • george bromwell
    • pma1123
    • Sdcryan1
