starquest 4g63 ?s
95twinturboawd
240
Feb 26, 2009
jackson, Michigan
picking up a 87 conquest tsi, i have a few ? on the turbo hot side can i put a evo9 on a dsm 16g? im planing on useing evo intake and exhuast mans.
thanks for your info
Yeah if I were you, I won't mess around with that engine. I know guys that try to squeak as much as they can with those motors and pay a lot in the end vs a 4g63 swap. If you want a good advise, ditch that engine and swap a 4g63 in there, there are so many sites to do the swap. Every year it gets easier and easier to swap them with others doing the swaps and telling what to do or not do.
This is a perfect site for you to learn the basics with those cars:
StarQuestClub.com
This one is really good too:
:: Project Zero G ::
StarQuestClub.com
thanks for the info, but back to my frist ? can i put a evo9 hotside on a dsm16g?
I have helped on getting a couple G54B to run.
The swap is using the stock 14g hotside on a 16g.
ALOT of port work needs to be done, Intake, exhaust mani, If your TBI.. then that needs alot of mod.
The design of the G54B intake sucks.
thanks for the info but the g54b will not be in the car i have a running 95 7 bolt, but now my ? is can i use this block, the monts are on the trans on a 2g, can i make monts for it and will they hold?
