turboglenn
- 6,375
- 123
- Nov 5, 2007
RIpley,
West Virginia
okay, i plan on doing a stand alone insall for the WiKi. there are 4 choices for the article i will write though, as to do all 4 would be forever and probably redundantly confusing if some one was trying to decide which one ot go by.
I only want to hear from people that either have a stand alone and it may be wired or not. Or people that are SERIOUSLY going to go stand alone SOON.
the write ups will be rather generic since evry ECU calls it's in and outputs something slightly different. it will mainly be focused around a haltech install, which would be similar to a LINK and the Autronic ECU's.
So here's what i want to know
1.) stand alone wired directly to the motor with it's own harness in a 1g
2.) same thing in a 2g (icludng 6 bolt swap and stock 7 bolt sensor setups)
3.) ECU wired through the a stock 1g harness which helps retain a stock look, keep all guages working and not interfere with airbag, speed/cruis control or any other factory functions (except the tach which i will cover a few ways to make it work in all of the articles)
4.) Same as 3 except on a 2G same advantages.
people that are SERIOUS, please let me know what you plan to do andwhat sytem you're looking at.. IF your going AEM plug-n-play, no need to reply, that ones simple enough for anyone to install, but too many damn complicated setup variables to try and go indepth on in a single 'net article.
Also, some systems i can help with some things that are ECU specific, mostly in LINK, Haltech, most AEM stuff,Accel DFi (hardley ever seen in a DSM), Autronic SM-2, SDSEFI (not one of my favorites) Motec (rich mans system) i will answer or do follow ups on teh wiki if you PM me about them when using teh write up
Also, if you have any requests on wiring additinal outputs (NOS,flatshift,dual runner manifolds) please make them known in this post so i can plan them in this write up ( this is going to be a long write up BTW, so don't expect it next week)
