ECMlink stalling issue cant figure it out
turbo24
57
Feb 17, 2011
hudson, Florida
OK so the car started cutting out one day while driving at highway speeds felt like a lack of fuel issue then it never did it again till a few days ago now it'll stall all the time i verified fuel pressure is good and steady when it occurs i did figure out that if i unplug my gm maf the car will idle (though it doesn't want to rev very well w/o the maf) it will just start and stall with it plugged in i replaced it and it seemed good for bout 10 minutes then right back to stalling again
I'm having same issue as you are almost exactly I was on highway and had loss of power like no fuel was getting to it. Did it a few times when I would turn it off and back on it would go away And now does it all the time. Check to see if you throwing any codes mine just started throwing one says wiring or the maf is just not working properly. Things that I checked and that you should too. Boost leak test check plugs and wires mine were bad, when I replaced them helped out a bit. Next step is were I'm at is trying to get another maf to test it out. Hope this helps you out a bit. If I find out what's wrong with mine ill let you know.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
