Spun Rod Bearing On 98 GSX
stephen_gst
89
Sep 30, 2013
Worcester, Massachusetts
So i purchased a 98 GSX about a week ago with a spun bearing in the bottom end causing a rod knock. I knew upon buying this car i would need to do a complete overhaul and rebuild the whole motor. Seeing how it has a spun rod bearing I am positive that the rod the bearing spun on is junk and im also positive that the crank is junk. The car still runs and its only ever turned on to move to a different parking spot at my apartment otherwise my landlord will tow it.
My main question is if i can still re-use the block in it if it just spun a rod bearing?
I will be bringing it to a machining shop to have it all cleaned out and basically be a 0 mile brand new block.
All forged internals Manley Crankshaft, Tri-metal Bearing, Manley Road and Manley Pistons
Will this spun rod bearing ruin my chances of reusing the block?
Have the crank checked the block have it examined for cracks chances are its ok, then grab some new bearings and a crank throw it back together been down that road but I had my crank cut and new bearings shes doing just fine. The block should be fine but the machine is inspecting it so you shouldn't have any issues.
i have been told the crank might be re-useable but id like for everything to be forged and 100% brand new and capable of holding 500awhp.... im the type of person that if one thing goes wrong ill replace everything and make sure its all brand spanking new.
The block is going to be machined if i dont see any cracks by Precision Machining & Balancing in Hudson, NH. My friend went there for his RB25 to be machined and they did fantastic work!
id stop starting it to move it around just in case the crank is good and your risking needing a new one just to move a car a little. block should be fine.
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 2g NEW OEM FWD Fuel Level Sending Unit
    2G NEW OEM FWD Fuel Level Sending Unit $85 + shipping & paypal fees* NOT the fuel pump hanger...
  • For sale 1g 1GA OEM Corner Lights
    1GA OEM Corner Lights $65 + shipping & paypal fees* all mounting tabs are intact * the...
  • Wanted WTB 1990 AWD manual Talon Transmission or shifter Forks
    I need a 1990 AWD 5 speed manual Transmission. The transmission has all the shifting forks...
    • 90rallytalon
  • For sale 1g 1g dashmat. Black.
    1g dashmat. Black. Overall good condition. Does have a tear where the dogear flap is on the...
