AL92
- 933
- 4
- Dec 12, 2003
regina,
SK, Canada
Ok yanking it out and rebuilding or replacing it. Few things that did wrong wondering if maybe that killed it.
I didn't use an oil cooler. Used 90 style oil cooler housing.
I ported oil relief hole since took out balance shafts.Maybe too much?
I used 10/30 dino oil not synthetic. Car leaked oil so much from so many places that synthetic would have cost too much.
I didn't install oil squirters.
I did have three overheats from sticking new oem therm. I shut car off each time immediately and no apparent ill effecst to motor that were obvious.No white smoke,no blue smoke so think no warped head. But maybe these overheats killed the bearings?
What is good amount of oil pressure to shoot for at idle and thru the range. Think heard 10psi for every 1000rpm so would shoot for 8000 rpm on my engine?
Oil was changed religiously in fact anally like six times in first 4000 miles.
I didn't pack the oil pump though first time. Used my impact to turn the pump on the stand though till oil came out. Not sure exactly how to pack the pump.
