- Thread starter
- #26
AL92
- 933
- 4
- Dec 12, 2003
regina,
SK, Canada
Ok .Well did use a 90 turbo oil housing as far as I know. And don't have any cooler. So sounds like that would be the reason right there. Not clear .When does it mess up when its cold out or when its hot out..What do you mean 80C.. 80 centigrade?
What holes on the 90 do I need to use for the cooler. and pics ? I was going to order a cooler didn't realize it would fubar my engine. Damn..that sounds like a very good reason for things to go bad.!
Bet you hit the nail on the head.
So if that was the cause so next time around here are things I would do different.:
Were exactly is this valve is it in he housing ,thought is was in the oil cooler??
Again any pics or diagrams for me to better understand this.
Number 1 use an oil cooler.
number 2 should I port or not port the relief valve in the housing.
number 3 will use oil pressure guage but where is good place to put it to make sure get good readings and do I want about 10psi for every 1000rpm?
number 4 should I install oil squirters?
Number 5 I will balance stuff this time around.
number 6 still might go eagle crank .Can someone say for sure if the 2.4 is forged or not? hearing different opinions. And so why do you guys figure those 2.4 cranks are breaking .Do you think its overeving or turning the cranks. I know to only polish them only. And what is safe redline for a 2.4. 8000?
Any onther tips will be seriously studied. I try to think a bit on my own but it can get me in trouble it seems. I saw posts on board saying no cooler was needed. But maybe they were using the sandwich setup which I hate. How can I tell if my housing is non turbo or turbo? Its possible it is non turbo I have no clue just that its a 90 style cooler type.If that was the problem wonder what will be salvageable from my 2.4. Maybe its toasted crank,rods,pistons,turbo ,everything. Man that would suck. I might build a 2.3 if my 2.4 block is wrecked from this. I do like having bigger than 2.3 on my mostly all street car.
Also anyone making kevlar timing belt for the 2.4 yet?
Also if this oil thing took out my nice turbo does fp fix them up. I think heard the bb and not rebuildable but not clear exactly what that means. Hopefully have not toasted that also. I had inline oil filter in there .I have so far seen no metal in the top end when took the valve cover off. Can't feel any and no visible metal. I will likely tear into the engine in the next few weeks hopefully. I have a lot on my plate with my other cars and only so much time to work on my 97.
So was having the oil sender on the housing useless also? I never saw the factory needle dip down when revving it.
