Splines, splines, splines...
k, The only diffrence on splines is the Shaft for the TRanny to x-case. The Drive shafts are the same. Rear ends are the same. ALTHOUGH on the Rear ends. You cant use 3bolt Axles in 4bolt Rear ends. Splines are diffrent on those too.
