Spindle replacements
costas14
489
Mar 7, 2008
quincy, Massachusetts
Need a new spindle possibly. Are the turbo awd turbo vehicles and non turbo vehicles the same in front suspension? How about a 1g? I got a 1g turbo eagle for parts out in the yard. Pretty much i got the whole spindle off with the axle frozen. We've tried torches, air hammer, air chisel. Anyone ever go to the dealer to pick one up?
As for the 1G, the pass side axles are the same. However, the FWD turbo and NT have the same drivers side axle but the AWD axle has a half shaft and smaller oil seal at the transmission.
i just need the spindle, i can buy a new hub and bearing and i already got the new axle
1g spindles won't work on your 2g. N/T spindles have the same part numbers as turbo's. The only thing you have to watch out for is ABS. If your car has ABS you MUST use an ABS spindle. If your car doesn't have ABS, then you can use any 2g spindle, ABS or non.
yea its got abs but the sensors wouldnt come out from the spindle, so we just cut it. the other side is cut to and when i got the car the abs didnt work.
