prophecy7115
- 345
- 4
- Apr 23, 2005
Miami,
Florida
hey i ran into a little problem my speed dometer stoped working?? wat could cause this??
fwdturbobov1996 said:On the back of the tranny under the throttle body kinda you will see a cable going into it. Unscrew it and look to see if the little rod in it broke.. if so time for a new one.
Not on a 2G. Electronic, no cable.fwdturbobov1996 said:On the back of the tranny under the throttle body kinda you will see a cable going into it. Unscrew it and look to see if the little rod in it broke.. if so time for a new one.
Yes, although you could weaken and use the search.prophecy7115 said:ok when i put my tranny in, there was a cable with a plug in the end that i connected to the tranny under the tb, if i remove the battery i could squeze my hand to it from the passanger side.. is it that??
. thanks alotfwdturbobov1996 said:On the back of the tranny under the throttle body kinda you will see a cable going into it. Unscrew it and look to see if the little rod in it broke.. if so time for a new one.
Defiant said:Not on a 2G. Electronic, no cable.
You're not the only one annoyed by it.prophecy7115 said:but its starting to get annoying to post all my problems on the newb section,
