Speedometer not working after I've tried Everything!
GSX HP
Mar 16, 2006
MGM, Alabama
My speedometer and Odometer don't work on my manual 420a Eclipse. I've replaced both the speed sensor and the guage cluster.... And I really want to get this fixed but I am absolutely clueless what to try next. Any help is appreciated.
next would be the cabling? the speed sensor harness?
does the cruise control work? I had the same problem as you once, and I did an engine swap, and it worked when i put it back together. during assembly i found a cracked wire on the harness.
