speed limitor removal
Status
Not open for further replies.
eldiabloz13
612
8
Mar 2, 2005
Fairhaven, Massachusetts
Ok im making my car turbo and, since im only going to be running around 8 psi should i get the speed limitor removed.also its just a chip right? how much would it be.
I know you can find some info on the tech articals, they say you need to remove a pieace and solder some stuff back together.
RamenPride said:
exactly. there would be no reason to put one on a car that came with 140hp stock
WOOOWWWWW.........it says on my FIRST post "Im making my car turbo" so obviously there will be more then 140 hp after it. Look man your a registered member and should know to read before posting.
RamenPride is saying that mitsubishi would not put a speed limiter on a non-turbo 140hp eclipse, no reason for it.
Status
