2G Speed Density Harness setup?
Stainbox12
378
7
Jan 3, 2006
Panama, Central America
Guys, I'm wondering if anyone has used the following setup:
Looking for an alternative to the one sold by extremepsi since the harness is already made on this one. Not sure if the sensor is "omni" but does it matter?
Any input?
I'll probably just buy the harness then since I really hate splicing wires. I'll buy the Omni sensor and the GM sensor elsewhere. Thanks guys.
Omni’s are hit or miss for people. The link below might be worth considering if you want to experiment. One other person on this site uses their 5 bar MAP sensor and says it is reliable. I’m testing out their 10 bar for oil pressure, but it’s too early to say if it’s reliable.
Trying to avoid going with an OMNI sensor since I've heard they fail a lot.
I was wondering if this kit would work on my 2g (AEM type)
Ive seen that usually the MAP sensor is hardwired to the stock MAF connector but this kit plugs directly to the TPS plug. Would it work the same?
I plan on tuning with ECUflash if that makes a difference.
