ECMlink Speed density 1g
Pat026
136
Nov 27, 2016
Milford, Pennsylvania
Picked up the kit from stm. Does anyone know how to install this type of connector to a 1g?
You got the wrong sensor. That’s a 2g style sensor. You have to get the other type of gm map sensor and make sure you run it’s own vacuum line for accurate manifold pressure.
That kit is normally for 2G or EVO who has MDP on intake manifold. That's why the kit doesn't come with a pigtail for MAP sensor. I think you have 3 options.
#1: Return that one and get an universal fitment kit which has GM style MAP sensor that comes with a pigtail connector, like in the link below.
https://www.extremepsi.com/store/Speed-Density-Bundle-Kit-GM-style-MAP-IAT-pigtails-and-bung.html
#2: Get a pigtail connector and an adaptor, like in the link below.
https://www.ebay.com/itm/Michigan-M...sor-VSS-MAP-connector-2G-DSM-EVO/192795224203
https://www.extremepsi.com/store/Extreme-PSI-2G-MAP-Sensor-Adapter-Mitsubishi-Eclipse-95-99.html
#3: Find a 2G MDP sensor connector or a speed sensor connector in local junk yard and modify your intake manifold to install the MDP type MAP sensor.
My mistake I saw it on stm said fitments were for 90-99 dsm mapsrformance had the same style sensor I'll be returning it Monday thank you all for the help
