Spark confused
95boostedGSX
48
Jul 7, 2011
Gering, Nebraska
Hey everyone im trying to figure out a spark problem .Today i had my plugs gapped around .35, and when i got on it around 4000rpm the car pauses for a second then goes so i thought this would be blowout so i re gapped them down to .28 and i think the issue has gootten worse do i have the right spark plugs? they are BPR6ES do i need to have a different gap?
You mean .028", right?
BPR6ES is the stock heat range plug so they should work fine. I think the stock range is .028" to .032" but I'm not 100% sure (it does include that range at least which means you're ok). You may have a plug wire or coil pack issue.
If the problem got worse than you probably have bad spark plug cables. I ran .024 at high boost levels and .028 at low levels. You may want to go too .026. I also would run ngk BR6ES. The missing "P" is for non projected plugs. I always had lower issues with knock when running these plugs. They are usually used in motorcycle and marine applications.
Ok ill give those a try
I Got bored tonight and decided to put my spare plug wires on which solved my problem. :hellyeah:
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
