confused
90blktalon
Feb 3, 2007
vinton, Virginia
My talon has been in the shop for a long time. Now it is finally close to being started. The mechanic working on it asked a question that completely confused me.On the stock setup there is a hose from the top of the turbo to the wastegate accuator. My question is, since i bought the sbr 20g turbo and fmic there is no place to connect the hose to the j pipe, Where does this hose connect to?
Run a line to connect the j-pipe to wastegate, the wastegate will use the j-pipe as a boost source. To regulate boost above what the wastegate is set to, cut the line in half and insert a boost controller in the middle.
I think what he is saying that their is no place to put the hose to the j-pipe..
is it an aftermarket j-pipe? if so what you do is tap it and put a nipple on it and connect the hose that way..
You will want to remove the J-pipe and drill a hole finishing with a 11/32 bit near the flange.
Once the hole is drilled you will want to tap it for an 1/8 NPT fitting with a nipple on the end.
When the fitting is installed you can grind off the excess of the fitting inside the pipe.
Re-install and you have your new boost source.
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
