SPAL fans......
jhines
66
Jan 3, 2006
China Grove, North Carolina
Ok, so I bought a 12" and a 10" SPAL slim-line fan. I want to install the fans to operater as stock.........what exactly do I need to wire up to make them do that? Should I just take the fans power wire and connect it to both the low and high speed power wires in the engine harness and the ground wires to the SPAL fan ground?
Basically I am saying this.........
Low speed power-----------
High speed power---------- SPAL power wires
Low speed ground----------
High speed ground--------- SPAL ground
Just do that on the A/C operated fan and the same on the radiator fan harness......would that work or has someone had better luck with some other setup?
Thanx for the help guys,
-Hines:dsm:
i wired low and high speed power together on the harness
and low and high speed ground
(basically can operat low and high speed )
no problems with it
with your wireing you have no lowspeed at all?? why would you want that?
Yea....that's what my diagram is meant to sya. I do want both speeds and I was thinking that I needed to wire them that way as you said. I was just checking to make sure it would work like that.
-Hines
