Spal fans hardwired?
ByrdClaw
144
Aug 21, 2007
Sacramento, California
I have just recieved my punishment radiator with spal fans for my 1g. I want to cut the harness and hard wire the spal wires to the stock wires. The problem is there are 3 wires for my stock harness,and only two for the spal. Im not sure wich wires go to what? any input helps.
Ok thankyou for your help very much! So I assume that the green blue,and the green and white are wired together and the black is ground? thanks again man!
Yeah i did alot of searching,but most are for 2gs. I have a solid black wire,a green with white stripe wire,and green with blue stripe wire on the factory harness. My spal fan has a blue,and red wire.
