- Thread starter
- #76
19BLACKGST98
- 711
- 3
- Nov 6, 2003
McKinney,
Texas
Thats the weirdest little setup I've seen. I would re-do all of that. I could see that causing a problem. I'm assuming you had your shop/mechanic do that for you?
What do you have in your car that requires a vacuum line?
I would run the wastegate to a better boost source, like the compressor cover or lower intercooler pipe and have your MBC or EBC between that.
The hoses were probably connected like that when he did the wire tuck.
The only thing I can think of that requiers a vacuum line in the car is the boost guage and I see it on the other side. Hopfully I can get back from the lake at a decent time so I can figure it out.
I talked to my mechanic yesterday and he has a v44 wastgate that I can throw on my car to eliminate the question of my wg being bad. Ill get him to tap the lower intercooler pipe and borrow a mbc to eliminate that as well.
Thanks for the help.
Edit: im an idiot...im sure the vacuum line leading into the car is from the EBC. I installed it back in 2003...why did I go through the passenger side though?
...It hurts because Ive had the car since 2003.
