2g420aeclipse
- 57
- 2
- Jan 3, 2016
houston,
Texas
I was driving back home then all of the sudden i couldn't shift to 2, 4 and reverse but i can shift to 1, 3 and 5. When I try to shift to 2,4 , & reverse it slides back to neutral it's like hitting a wall but Sometimes it does shift to 2,4 & reverse but it feels like it barely grabs it like it wants to slide back to neutral. When the car is off i can shift normally I could go to 1,2,3,4,5, & reverse and have no problems except when I turn on the car i can only shift 1,3, & 5. I also heard a popping noise and i felt the vibration on my shifter when that happen that's when i couldn't shift 2, 4, and reverse. Is it possible that my shifting cables snapped? i look under the hood and nothing came loose unless is in between which i cant see. but i decided that i'm going to buy new shifting cables but before i buy it, could that be it or could it be something else. I don't know much about shifting cables and i was wondering if someone knows how to diagnose. Thank you for your time.
