Solid rear motor mount?
swifteagle
317
8
Jan 18, 2012
livingston, Texas
Do you guys think I could make my rear motor mount solid to keep the motor from moving make and forth and just use the poly inserts for the rest of them?
IF you are going to go solid on one, you might as well do it on all of them. You are going to have awful vibrations inside the car with one or all solid mounts. I would just go with urethane inserts.
I have to lower the point of where the bolt go's through the mount on the subframe. So I was thinking of taking and welding up the mount.
I really don't know it has the 195 bracket on the motor but is like the mount that bolts to the subframe is to high.
You don't have a rear automatic mount do you? You shouldn't need to make a custom mount in order to make this work. You just need the right parts.
Is there a difference in height in the auto and manuel. I think the front is fine.
not sure why my mounts is making the motor sit slanted but I think i'am going to lower it and use the inserts
