For Sale SOLD!!! For sale a 98 GSX 5 speed rolling shell rust free
ulitka
151
12
Apr 9, 2009
Raleigh, North Carolina
For sale a 98 GSX 5 speed rolling shell rust free. I hold a clean title on hands under my name.
It was a Florida car then North Carolina, car was never exposed to salt, no rust.
Shell comes with new brakes, driller slotted zinc plated rotors, new pads.
Hand brake is working great. Brake system was flushed with fresh dot3 fluid
Stainless Steel braided brake lines front and rear.
New coilover shocks with adjustable camber in front and rear.
Wheels are in great shape. Tires still have some thread but need to be replaced.
All axles and propeller shape are in great shape.
Rear diff was upgraded to KAAZ tunable limited slip diffirential with clutch and plates design.
All bearings and races were replaced at the time of upgrade, lash and gears mesh were adjusted as per oem repair manual.
Solid rear diff bushings. Transfer case will included.
Polyurethane bushings in suspension parts.
Upgraded sway bars. Strut tower braces.
OEM ecu. Solid bushings in shifter cables.
Battery location in trunk.
6AN fuel lines from tank, to external Bosch 044 fuel pump (pump not included), to engine bay external fuel billet aluminum filter.
6AN return fuel line to external fuel cooler and to the tank.
Stereo and amplifier
Shell does not have the following components:
Hood
Fuel pump and hanger assemblies
EVAP components
Battery
Exhaust
Engine
Transmission
NOTE:
Power steering pump and cooler included.
Air bags exist but are disconnected
Fuel pump wires pigtail was cut off and provisioned for external relay for thicker gauge wires into fuel tank pump and external pump.
OEM fuel lines exist but tapped off.
Koyorad radiator has some bents but no leaks.
Please PM me for any additional pictures. Picture albums are here:
https://flic.kr/s/aHsmHjsSyt
https://flic.kr/s/aHsmHnkRGK
Price is $2500 picked up from Raleigh NC residential location. Car is in garage and will need to be rolled out on to a flat bed tow truck.
