420A Socket stuck in crank hole
Twinkeyman
Jan 19, 2026
El Paso, Texas
I had a friend help me with a project when i was gone now theres a socket that is expanded in the crank hole. I have tried many solutions but none seem to work I would appreciate your help thanks
How does that even happen? Regardless, it has probably ruined the threads for the crankshaft pulley bolt, which could potentially deem that crank as scrap metal.
My idea would be to use high strength epoxy to glue a long rod to the socket. So you now have a means of pulling it out or maybe using a slide hammer. The condition of the threads should be a large concern.
I also thought about the bread trick. At this point it wouldn't hurt anything besides wasted food and possibly energy. In the past I've used JB weld and a throw away extension to snatch stuck sockets back out. Not in this scenario though.
