So I thought 1G's didnt have map sensors?
but
190
Apr 7, 2009
Ridgecrest, California
So I pulled codes off link,and it says manifold absolute pressure malfunction,and intake air temp malfunction. Im confused because I thought I didnt have either of these?
Would this be because I'm running a 2g maf?
I'm having problems building boost in any gear.
The MAFs have a pressure sensor in them that takes the barometric pressure in the split second before the car is cranked. Those 2 codes would be possible because the MAF is wired wrong.
Ok thankyou,I will check the wiring. I hard wired it so,I'm sure there could be a problem there. I replaced the maf yesterday and it took away one of the codes,but threw those two codes.
Im running very rich at cruise, 10-11.1,and It wont idle.
Would that be affected?
