so I just installed a new ISC...
Daedalus
323
Mar 24, 2003
Omaha, Nebraska
and it didnt do one damn thing to help my idle problem.
Now the car idles very high (1500) and seems to "stick" on the throttle for 2-3 sec when I push in the clutch. After about 5-7 seconds the idle settles. Now, I know all you guys get in here is idle this and idle that questions, but I have done the searching, research and crap, and would appreciate your help.
I am fairly sure I have a brake booster leak because my idle goes down when I step on the brakes, and decreases depending on how hard I press down. Is this the correct diagnosis?
The car is a manual non-turbo. What else could it be?!?! I want to get the idle grimlins sorted before spring!
Thanks a lot for your help!!!
its new or new to you? if you bought it off the trader or whatever, i suggest you test it to see if its trash or not.
I have tested both ISC's (a little late) and they both are fine. Ohm range was allmost perfect. I did however check the BISS screw... the lil bastard had loosened up. I tightened her down all the way and the idle is much better, its still rough and iles around 900-1000 with the screw all the way down so I dont really know why that is... Are there any other factors that could artificially inflate my idle speed??? I mean, if the BISS Is tightened down all the way, and i'm still idleing higher than the 790 rpm stock isnt that a problem???
Keep the help coming, I greatly appreciate it!
My car idles with a good ISC and a a new o-ring on the biss at around 8-900 with one turno out on the biss. Try replacing the O-Ring on the biss it shouldn't be able to back out on its own like that
lumpy idles in 1g is usually alot of things. LOL.
main problems usually are:
Dirty Throttle body, Bad ISC, In-properly adjusted Biss screw
Other things may be:
Leaking ECU caps, Vacume Leak, Compresser Outlet elbow Leak.
