just installed a 50 trim ;-/
seahorse
35
Jul 29, 2005
yonkers, New York
i have a 1997 gsx car has a few upgrades dejontool side mount,2 1/2" upper i/c pipe, 255 hp walbro 3" intake with k&n filter stock exhaust just a test pipe, greddy style muffler and s-afc ..the turbo is a pte 5031 with a tial 38mm on a ported 95 manifold...evo ported o2 housing..ok there's my question i installed a set of 680cc pte and it seem to be running real rich ..i hooked up my PLX wide band and i had the afc setting to -45 and still running 11.0 at wot..i think i'm going to install a set of denso 550 cc injectors ..i think it will be fine..what u guys think?? what a/f should i tune for ..i heard 12.0 12.5 good?
try to stay above 11:1 if you can unless your really pumping out the psi and fuel. what about your fuel pressure? got it regulated enough? you dont want any unwanted high pressures bleeding past the injectors. I hear the Walbro 255 will put a squeeze on your stock FPR. any other running issues, etc?
i'm running 18 psi ..car does'nt feel any faster then the 14b i just took off :-/
**Update
i just installed a set of 550cc cause i though the 680cc were to big ..it seems alittle better now its -30 the settings on the s-afc before with the 680cc i had to go -45 and it was still to rich ..i am running a/f at wot between 11.5 11.9
wow thats rish im running a 1st gen with a walbro 255 and pte 680s and it doesnt seem to be real rich. ill ask my tech when i go in to have my motor swaped. There is however the most iratating bubble in my fuel line right befor the rail, any ideas on how to fix, no leaks just noise.
