50 trim installed, finally!
Status
Not open for further replies.
sarge
261
Nov 4, 2003
I picked up one of the Precision turbo SCM 50 trim turbos about 2 months ago (the one rated for 450hp). Jay and matt (if you are in the carolinadsm club you have probably met these two guys) were kind enough to install my turbo on christmas day. the 50 trim replaced my frank Jr. 17c turbo. The 17c was a pretty good turbo, but I decided I wanted to go to something bigger.
Well, later on christmas day i picked the car up. Boost was set at 12psi, and it was incredibly strong there, roughly like 17-19psi on the 17c. Several days after that i messed around with the wastegate actuator arm and got the base boost level up to 15psi. 15psi on this thing is fast. About as fast as the supercharged roush stage 3 mustang. I happened to run into one on the highway about a week ago, and from 60-140mph, he had less than 2 cars on me. Later I talked to the guy and his mustang put down 328.8whp, and ran the 1/8th mile in 8.07, so I am guessing that my car is making somewhere close to 300whp. Thats just a rough guess though.
The pte 50 trim w/.63 ar is an excellent turbo. I have this in conjunction with the dejon tool 3 inch intake. I can hit full boost in 2nd gear at less than 4000rpm, and in gears 3-5, it hits full boost by about 3600-3700rpm. Very impressive for a turbo that size i think. Currently its pretty untuned. I took the SAFC settings for a big 16g equipped car and 550's and FMIC from RRE, and just added several % more fuel in the 4-7500rpm range. EGT's peak at about 850C on runs from 0-120mph. I was planning on on having the car dyno tuned at 17-18psi, but my car started to burn more oil than usual (valve stem seals are starting to go, 120k miles on them). So instead I will have the head rebuilt on my car, then probably in the summer get it dynotuned after the head rebuild. Or, if you guys think that dynotuning will still be effective on a car that has bad valve stem seals/guides i may go ahead and have it done.
I didn't see any good reviews of these turbos, so I figured I would write one. Tell me what you guys think!
Squackdiddy said:
what do you guys think about this, t25 straight to 50trim?
Well it depends if you have the supporting mods or not. To fully maxamize the 50 trim you will need at the least:
Fuel pump
injectors (650s or bigger)
FMIC (stock smic will heat soak very very quick)
AFC or some other fuel tunning device
New intake pipe of some sort, and some kind of 90 to attatch the licp
Exhaust, dp, porting on mani and o2
Sq
yeah the setup is going to be similar to that. is the power difference going to be to much to handle? or its all good?
Ive been running the AGP RS-49 for about 3 weeks now. I had some issues with some severe exhaust leaks(reused stock bolts for the 3rd time and broke two :cry: ) All is fixed now and the 50 trim has shown my ignition issues. I stumble a couple times in a heavier load gear like 3rd. So im thinking im just not getting a good combustion.
Pull is definately stronger than the B16g, but im also running more boost and back at sealevel as opposed to Colorado high altitude. If i manage to get some new wires, and the rear motor mount fixed this week then ill take it to the track on friday to see where im at.
-Dallas J
I just purchsed Bullseye T04E 50trim..49lbs/min
got this supporting mods:
FIC 850cc,
walbro255,
Aeromotive FPR+fuell feed lines from SBR
Ordered LP tubular mani
Custom 3inches O2housing,whole 3inches exhaust,external dump(internal gate)
31*12*3FMIC, 3inches In/out, custom 3inches Alu short route pipes,
MafT setup-my Tuning tool! I know crapy Maf Translator,but I spend money in this stuff.checking DSMlink :thumb:
Datalogger
8lb Fidanza Flw,SBR3500clutch/street disc
3inches Intake/KaN,
Denso Iridium Sparks
underdrive pulley
supporting Gauges-A/f,EGT,Boost,tranny temp,Oil press
Will make custom CO2 spraying
I hope can make around 350+AWHP on my awd Eclipse On Stock Engine/head!
I know tuning is very importen
what do you guys think?
Status
