Small idle problems after first start up
Marceldsm
321
3
Jan 13, 2010
Montreal, QC, Canada
ok so i finaly got my car going
1g dsm awd
1g stock engine
no balance shaft
arp headstuds
new headgasket
new head wit oversized valves and delta cams regrinds 264 272
fidenza flywheel
stage 4 xtd clutch
850 cc injectors
2g maf
costom chip from MY1GDSM( THANKS A LOOT)
afpr
car starts and idles at 3000 rpm ( my tb coolant lines are not there )
my afpr says 60 psi of fuel pressure, car stals
ajusted the fuel pressure it says 15 psi new, car starts revs and everyting looks fine to me
any sugestions
did a boost leak test i tink there is a boost leak at the tb becouse after 25 psi there is a small leak from somewhere.
no leaks from injectors ( seal) no leaks from intake manifold
no leaks from the intercooler or couples
bov is fine no leaks there
my wideband says 11 ro 12
so what can it be
check the throttle body gasket you might need a new one i had the same issue with my 91 laser changed it out and it was fine to bad i sold it cant wait to get a new dsm
why is your fuel pressure so low??? and why did you make such a huge change?
