- Thread starter
- #126
andymoraitis
- 3,239
- 161
- Jan 25, 2004
Utica,
Michigan
Luke: I definitely need something bigger. The 35R sounds very attractive based on your spool numbers and the top end flow would be fantastic. I may look into one of those for the 2008 season. For now, I'd like to do the clutch and see what she's got on the current boost level and tune. Looking at the map, it's perfect for my setup.
Greg and Paul: I suppose the best thing to do would be to run it at the track and use their density altitude readings which would include baro and water grains for corrected altitude (like they do in NHRA competition). For now, these calculations seem to be pretty good.
Interestingly enough, when I got on it last night boost leveled off at 27 (PR of 2.89) instead of 28 so perhaps she'll stay there. I also had a chance to look at spool and she picked up around 100-150 RPM from the TB swap so there was a positive move in that direction. Attached is a new map for 27 psi with a projection at 50 lbs/min based on 800 ft. ASL. If she flows more than 50 it'll be worse but this turbo was marginal at best, especially in cold weather.
No worries. I have a strong feeling she'll easily meet my goals.
, my eye's were in the back of my head...cant imagine what yours goes like. I want a ride hahaha. What clutch you going with buddy? ACT 2900? Or got a new idea?
